Hi, I am planning to fabricate a washer pan (30"x29.5")
But I realized some work done recently might have create challenges in this regard
My plumber drill a hole at the top right corner of my very narrow closet, which is newly laid with tiles ---- so i really dont want to drill another hole to make this work. This closet is used as laundry room for stackable machines. the hole drilled is abt 2 inch diameter. the problem right now is i need to find a flange that works with a 1-inch or 2-inch PVC pipe, so that i can hook it up to a stainless steel washer pan (to be fabricated with a hole at the top right corner) then connect it to an emergency PVC pipe.
i am talking abt something like that: http://www.homedepot.com/b/Plumbing-Pipes-Fittings-PVC-Pipe-Fittings-Fittings-Flanges/N-5yc1vZbuvl
can anyone tell me where can i find a 1-inch or 2-inch PVC pipe flange?
the ones i seen out there seems to be 3-inch or 4-inch only??
because of this mistake in drilling hole at the wrong spot - i guess i would have to then cover the hole with a shower strainer (otherwise washer leg cannot sit on a leveled surface but will dip down into this hole)
please advice me on this predicament, thanks!
