Against my better judgement, I ended up using the blue/silicone waxless ring.
The initial concern is the flange (relatively new home, 5 yr) was installed crooked...lucky me.
it is 1/8 proud on the left and flush on the right.
The waxless instructions say "if flush or 1/4" below, use the spacer" well the spacer + waxless = too proud for the toilet. it sits was too high. So I used the waxless only, applied to toilet first and carefully dropped in place. Was easiest install i have ever done.
Should I have used the spacer and maybe the base bolts would snug it down nicely?
i was more afraid of cracking the porcelain in this situation.
Couple things to mention:
1. only hand tightened base bolts
2. used thicker closet bolts, instead of the ones from the Waxless kit
3. have not siliconed the toilet base yet
4. no leaks that i can see visibly, flushes like a beast.
Should I tighten the bolts a hair more, silicone the whole perimeter, and see if odor persists?
Or check the waxless setup and possibly ditch that?
thank you folks, also for your extensive reviews on toilets. I ended up with a Toto Drake. It is a beast. I am very pleased with the quality of the unit as a whole. Flawless. As expected by all of the positive notes on this forum.
