I ended up doing what Terry suggested and bought a tube of the clear stuff.
I was originally going to do that, but decided to caulk all the way around. The main reason for this is a toddler aged boy. He gets a lot of water on the floor from the tub next to the toilet, and possibly will be getting urine on the floor around the toilet once he starts standing. If I didn't do the entire base, I don't know that I would of done it at all. But the good thing is I would still be able to see leaking from the basement below.Did you leave the back of the toilet uncaul
Did you leave the back of the toilet base uncaulked?
You've probably seen in your research that this is commonly done by some of the pros, so that if there is ever a leak in the wax seal (or whatever interface you use between the toilet and the closet flange), you can get evidence of the leak hopefully before it rots your subfloor.
I thought the area around the base had to be totally dry so the caulk didn't trap and seal any moisture in? (Obviously I am not a plumber or handyman, just a clueless homeowner trying to do things correctly)
in our area, the inspectors check the back of the bowl to see if the caulk was left out, and if so they reject the job.
Wow, Terry, great video! Your son made carrying the toilet look so easy-no way am I trying that! I have a question about the part where Jamie caulks the bowl. I noticed he seemed to make the area damp first, then applied the caulk. I thought the area around the base had to be totally dry so the caulk didn't trap and seal any moisture in? (Obviously I am not a plumber or handyman, just a clueless homeowner trying to do things correctly)
To AfroJoJo-you're not the only one who puts "much thought and research" into toilet decisions-LOL
