IrishSwede
I am about to install a prefab (tile redi) shower pan, unfortunately the drain and pipe are fused together and I only have above ground access to connect the drain pipe into the coupler below.
The trap is cut through a floor joist, to help brace the pipe (and raise it slightly) I placed a few pieces of tar paper to elevate the trap 1/8". Will this cause any harm further down the pipe by adding strain? I also (on sound advice I received here), placed a block of wood and some tar paper under the trap, not to elevate it, just bracing it for when I press the pipe down into the coupler.
One last thing...when I lay the pan down on the 1/4" - 1/2" troweled mortar will the pan push through that to the floor? Or do I need to account for that as well.
