Ingeborgdot
I had new cabinets put in and the electrician came and put in under cabinet puck lighting that had transformers in the cabinet. The wiring is all behind the wall except for the wire running to the pucks. My problem is that the electrician wired 4 20 watt lights to a 12531BK 60 watt transformer. You know what happens next. The lights are rather dim especially compared to the 2 on the right side that are connected to another transformer. These are made by Kichler. What can I do? The cabinets are in and I don't want the guy back. All I need to do is switch to a larger transformer right? If so, does Kichler make an 80 watt transformer? If not, who does and what should I do? Thanks.
