Quick question: What does the plumbing code say about sharp 90 degree elbows? I picked these up instead of the rounded 90 degree elbows for CPVC connections inside the house.
Thanks[/QUOTE
CPVC is for water pipe. Most of the time it dosen't matter which way you want to run them, if you are talking about pvc for a drainage system, short fittings are used on horizontal to vertical, and long sweeps are used from vertical to horizontal, luck.
