Dripping water filter after replacing cartridge
Rman
Master mechanic
northern NJ
I have a Big Blue model 10 installed before water softener with pentek sediment cartridge. I need to change out the cartridge monthly because of sediment very fine after New well drilled 1 yr ago water tested great.
When I replace the cartridge the first time I install it leaks. I then unscrew the canister and flip the O ring and most times it works
So I bought new O rings on line and same problem occurred with dripping?? Yes I do lube up the o rings with silicone grease for water filters. I’ve now also wipe thoroughly the inside of the filter cap. Cheap o rings or am I stuck replacing the whole assembly?
Real pita with bypass valves. Thanks
Your filter housing may not have been the Pentek Big Blue.
Wipe the inside of the filter cap??? Wipe what? Not silicone grease. Only the o-ring gets a light coat of silicone grease.
You may indeed have the wrong o-ring.
Supposedly you should just tighten by hand, and use the wrench to loosen. But maybe you need to snug a bit with the wrench.
