Rman
Master mechanic
I have a Big Blue model 10 installed before water softener with pentek sediment cartridge. I need to change out the cartridge monthly because of sediment very fine after New well drilled 1 yr ago water tested great.
When I replace the cartridge the first time I install it leaks. I then unscrew the canister and flip the O ring and most times it works
So I bought new O rings on line and same problem occurred with dripping?? Yes I do lube up the o rings with silicone grease for water filters. I’ve now also wipe thoroughly the inside of the filter cap. Cheap o rings or am I stuck replacing the whole assembly?
Real pita with bypass valves. Thanks
