Drain rough-in and p trap placement for bathtub
Is this p-trap and drain functional?
  • yes this will function and the tub will drain
    Votes: 0 0.0%
  • no way man
    Votes: 0 0.0%
  • Yes but will likely not drain or smell
    Votes: 1 100.0%
  • Total voters
Scott Montross
Oregon
Long story short. Bought a house built in 1940, its awesome. Except there was no bathtub only a 60x30 mortar bed tiled shower. Wife requires a bathtub, so here we go. all is well through demolition and prep of the space. New subfloor installed, tub overflow drain assembled, tub fitted all looks good. Except I am having a hell of a time with the drain rough in, the positioning. Drain connection is 1 1/2" galvanized, I attached a 1 1/2 inch Fernco flexible coupling. attached to the other side is a 45 degree street elbow oriented horizontal and joined to 3 3/4" long piece of ABS, which feeds into the p trap. in order to reach the rough-in location for the drain I have to rotate the inlet to the current position shown in the photo. I prefer to not have to move the existing vent and stack. Is this even a plausible configuration? I welcome any help or recommendations.
You can swivel the trap anyway it needs to go to work.
The coupling should be a shielded coupling though to prevent the sagging that will occur over time.
Scott Montross
Oregon
Easy enough. I considered the shielded coupling after reading a few of your other posts....However while purchasing supplies I was talked out of it. I will never again waiver on my "Trust in Terry" :) Thank you
