I noticed a slight water stain in my ceiling just underneath where my upstairs bathtub is located. After close inspection of the tub i noticed that half (left side) of the Drain flange is not sealed directly to the tub. After some testing to rule out possible leak issues the problem seems to be coming from improper seal connecting to the drain flange and tube.
I unscrewed the drain flange and replaced it with a new one. however, upon screwing in the new one, i noticed that it was screwing in crooked and on a angle. The rubber gasket seems to be in good condition. I removed all of the old plumbers putty, cleaned the inside threads of the drain shoe, reapplied new plumbers putty on the drain flange (not threads) and screwed the drain flange back in. It still will not seal properly and is still screwing in crooked. (however, the last time i did it sealed a bit better but still not perfect.)
Does anyone have any ideas of what caused it to screw in properly? It doesn't seem to be cross threaded as it screws in without force, just on a angle.
Is there something wrong with the gasket? does it need to be thicker?
is there an alignment issue with the drain shoe?
Is there anyway i can fix this without cutting a whole in my ceiling?
