AZHobie
Looking for friendly advise on this problem. I took the mirror down and updated what I found.
The picture is what I have now as was originally built in 1988. The left sink horizontal drain is 2", the right sink is reduced to 1 1/2". The vent is 1/2" above the cross and 2" below that. There is a vertical clean out just below the cross connection going to the exterior of the house. The vent continues up to 48" above the floor then left turn horizontal for 36" then turns up between two high long (wide) windows through the roof. The orange tape represents where the vent is and where I would like the the new sinks, X marks the two spots.
The problem..I am adding new cabinetry and the new sinks need to be moved. The left one will move left another 30" bringing its new location 72" from the vertical stack. But the right sink will have the center of 33" cabinet almost exactly where the vertical drain/vent is currently located. Any Idea how I can fit the right sink drain so that it is near center of the cabinet. Glendale is IPC code.
Thanks for all the help from everybody. I assumed the vent deviated toward the right wall on the first post.
