Dwassner
I sold my AIO and am looking to build a chlorination setup. I see kits online that come with all the components for a full setup but am skeptical about if I can buy the individual parts separately and have a better setup for cheaper.
-How do I size the retention tank? I am guessing something like: (X gallons per minute) x (X minutes of contact time), but am not certain.
-I see some tanks can be equipped with pressure and vacuum relief valves. Do you think this feature is worthwhile?
-would you recommend an in-line mixer?
-Aside from ease of plumbing, is there any advantage to tanks with both the inlet/outlet on top of the tank vs those with one on top and one on the bottom?
-how do I size the cu ft bed size for the carbon filter? I am guessing something like: (ppm of h2s + ppm iron + ppm residual chlorine) x (gallons per day) x (days between regen), but am not certain. Is there a standard amount of 'used' and residual chlorine that a cu ft of carbon will hold until maxed out?
Thank you!
Dustin
Thank you!
Dustin
