William J Sommariva
Never-ending Project
Last phase of my never ending project. Instead of guessing how many heads I can use per zone I did some tests as follows:
From a 1" PVB through 300 feet of PE I tested flow rate and pressure. That is at the end of a 300 foot length of 1 inch pe I have 56 psi and a flow rate of 7.5 gpm . If my Hunter side strip heads use .45 gpm at 40 psi can I use 16 heads on this zone? Seem like a lot.
Thank you.
Thank you.
