Redbird611
While trying to update the handle/trim on a Delta shower valve I ran into a problem. After removing the escutcheon I discovered that the valve bracket was not installed on a stringer, but rather loosely attached behind the valve. One of the tabs with the escutcheon screw hole was bent slightly and I couldn't get both to thread at the same time.
Unfortunately, after manipulating the bracket too many times it detached (or maybe was never attached) and fell down between the walls. Now I'm trying to decide how to address this. The valve seems reasonably secure despite the lack of stringer. From what I can see the upper copper pipe is strapped to metal blocking a few inches above the valve (high rise condo). I'd like to find a way to attach the trim properly with minimum expense or wall damage.
The only idea I have so far is to open an access hole in the opposite wall (closet thankfully) to place a replacement bracket on the backside of the valve, then wire tie the bracket to the valve so it doesn't disappear down the wall like the last one. That seems a little jury rigged, so I'm wondering if anyone has seen this kind of valve installation before and might have better ideas.
