Trim kit for this older Delta 1700 valve
Jetboy55
Wisconsin
I have this Delta shower/tub faucet that I think was installed in the mid 2000's. I replaced the cartridge in it about a year ago and what I know
from the research I did then, it is a Delta Monitor 1700 Series pre-2006, and the cartridge I put in it was a RP32104, and it worked flawlessly. Now I
want to change out the trim (its currently chrome). When looking for a trim kit (I want black) I see lots of options for 1700 series, and for 17 Series, and was wondering if that is the same way of saying the same thing. I also don't know if they will fit this faucet, as I assume the rough valve is not a modern "Multi-Choice" valve. Again, it uses the RP32104 cartridge, so I need help finding a trim kit in black for it.
Jetboy55
Wisconsin
Thanks. The trim comes with a new cartridge, which I don't really need right now, but anyway, is it possible that the cartridge with the new trim won't fit my valve? Also, will the 17T trim kits work, even if the cartridge wont?
Marlinman
Jacksonville Florida
The cartridge in the current T17 trims will not fit your valve. You will only be able to use the trim. T17T trims will not work with your valve.
Tmc1306
Tallahassee, Fl
Did you end up finding something to replace your fixtures with? I have the same delta set and would like to upgrade the fixture.
