Delta Roman Tub, What model number handle base ring do I need?
Discussion in 'Shower & Bathtub Forum & Blog' started by DEcosse, Feb 10, 2019.
  1. DEcosse
    DEcosse New Member
    Aug 16, 2015
    Livermore, California
    I have an old (circa 1990) Roman Tub Filler set
    I'm in the process of updating the trim kit to Chrome
    I'm having the Spout Chrome-plated (impossible it seems to find replacement) an already have chrome H65 levers;
    I can have the handle base rings plated, but given the relatively expensive cost of plating vs new rings, would like to see if I can find the ones I need and just swap them out.
    The Original (see image) has an OD of 2.5" and an ID of 1.25" - I believe it is Delta.
    Also, original has 'flats' but don't really care if replacement does or not - as long as thread size is the same is primary requirement
    (I had thought might have been RP23094 but from other research appears that ID for that model is 1.325"?)
    Thank you for this great forum!
  2. Marlinman
    Marlinman In the Trades
    Dec 13, 2018
    Florida
  4. DEcosse
    DEcosse New Member
    Aug 16, 2015
    Thanks for your reply - much appreciated.
    However t's not a 27 series - it looks quite similar but there is significant difference in the design of the spout seal - on that one you linked, the o-ring seal is on the rough - on mine, the seal is on the spout itself and is male fit into the rough
    (in second image below 0-ring has been removed )
    From what I can gather the RP23094 is 2-5/8 OD and 1-3/8 ID - this faucet thread is definitely 1-1/4" ID and 2-1/2 OD
    The OD is immaterial but the ID would need to be correct of course - I'd be happy to stand corrected if the RP23094 really would fit - I'm measuring with caliper across the thread and it's definitely not 1-3/8
Similar Threads: Delta Roman
Shower & Bathtub Forum & Blog Delta Roman tub faucet from 2000 Jul 9, 2019
Shower & Bathtub Forum & Blog Delta Roman Tub faucet, old polished gold from 1995 Jan 26, 2018
Shower & Bathtub Forum & Blog Delta Lahara Roman Tub Faucet Installation ( faucet replacement ) May 1, 2014
Shower & Bathtub Forum & Blog Delta Roman Tub faucet for Whirlpool, tub spout Sep 30, 2013
Shower & Bathtub Forum & Blog Help! Delta Roman Tub Faucet with Handheld... Apr 12, 2008
