Delta faucets and PEX C-- cutting
Brian Schreiber
Elk River, MN
I want to cut the lines shorter off the Delta faucet now installed. They are too long when trying to retrofit a Watts sensor valve manifold under them and connect it all . . . CLEANLY.
I simply need to know what exactly to buy to replace the existing ferrules on the two PEX C lines. Once cut I want to be SURE I replace with a compression ferrule that will WORK.
thanks!
Plumber69
Prince Rupert, British Columbia
Usually the faucet would already come with what you need
thanks!
To be clear, you don't intend to cut anything that Delta supplied, right? You want to cut a piece of PEX-C and do what with the cut end -- put a connector on it that can go to a valve or something?
Or did I misunderstand?
Terry H
Alabama
I like the Rehau PEX cutters but any will give you a nice cut provided the blade is not dull. Then use the nuts and ferrels provided with the faucet. The nut first then the ferrel with the sharp end pointing down into stop.
Edit: you can safely loop that stuff though as long as you do not kink or put in a bind. There is an art to getting them in I’ll see if I can find a picture.
Each type of pex will have a minimum bend radius, and of the three types, -A, -B, and -C, type -C is the stiffest, and has the largest bend radius. But, if you want to make the best right-angle bend without worrying about kinking, use a bend support bracket. It's best for the pex to be already pointing at the fitting when it's naturally installed rather than putting tension on the fitting and tubing. Often, though, there's enough room to make a nice bend into the fitting without issues.
