TVL
This is a single phase 240 VAC circuit - 6.5 amp FLA rated motor .................. correct?
1- Not knowing how this circuit OR its components are actually wired, I would have expected the amp draw reading to be equal on each hot leg (or very close to being equal).
2- The amperage from each hot leg in a 240 VAC circuit are NOT added to get total current draw. Again, the two hot legs generally read about the same, but if not, the higher amp reading is the actual amperage being used in the circuit.
3- If this is truly a 240 VAC single phase motor rated at 6.5 amps and this electrical circuit isn't being "shared" with another component, I would expect you to get roughly 6.5 amps on EITHER hot leg when the pump is running full open. Open up 2 or 3 faucets which will allow the pump to run at full amperage and take another reading.
