Spencer Nethercutt
I’ve been trying to get a well on my property back on, it quit being used after seismic surveying in the area was done years ago that caused iron in the water. I’ve lifted water from the well multiple times using compressed air and it seems to have cleared up.
It’s a 2” casing that is said to have a TD of 140’. I picked up a used Gould’s SJ10 that I have wired up 230V. I ran a strainer, a 2” packer ejector with the nozzle and venturi installed on the bottom of 100’ of Poly. I filled up the casing and tubing, installed the pump with the casing adapter and then primed the pump. Would build pressure, but not over 45# even with a closed ball valve on the upstream side of the regulator it still doesn’t build over 45#.
Prior to installing the pump, installed a wye on the casing above ground level so that I could treat the well if needed without removing the pump. I hooked a water hose to the wye to prime the system. Even with the hose hooked up feeding water into the well, making sure I have water coming out of the discharge before powering on the pump, it still won’t build over 45# with the valve closed on both the water line going into the casing, as well as the valve on the pump discharge closed. Shouldn’t the pump be capable of building pressure greater than 45#?
I do not believe I have a leak, as I can hook up an air hose to the wye on the casing and allow the air to pressurize the system to 65# and with the valve on the casing and the discharge side of the pump closed, the system maintains that pressure overnight.
I’m reading pressure at two location, one being the 1/4” plug on the pump itself, where I’ve installed at vacuum pressure gauge. The other location is on the upstream side of the pressure regulator.
I ended up pulling the pump back off, and pulled the packer back up 25’ to a depth of 75’, installed the pump back, primed the system with the water hose, and still the same result. I’ve set the regulator to the suggested 45# and it will barely build enough pressure to dribble out of the discharge. Even with a water hose hooked it ore wye on the casing and a check valve installed to prevent fluid from being pushed back into the water hose, pressure still won’t build over 45#.
My only thought at this point is seals on the pump, I am looking for other thoughts and opinions and guidance. Any an all input is appreciated.
I’ve about decided to make my own 18” long brass rod pump using parts from work and 2” leather cups, and then fabricate a miniature pumping unit that will be belt driven. I have years of experience with these types of artificial lift systems, but water well systems are not my area of expertise.
