Curve PEX around niche?
TheGewp
Washington County, OR
Are there any drawbacks to running a pex line from the mixer to the shower head like the picture below? What size pex should I use, 1/2 or 3/4? I am redoing the shower on this side of the wall and want to put a niche in where the current shower line runs. Thanks!
Not a problem. 1/2 is good, but you have to figure out what goes at the elbow. A drop-ear elbow screwed into some wood, that you would add, is the common way.
TheGewp
Thanks! Yeah planning to add a 2x4 and a drop ear for the shower arm. I would likely come straight across the top too and eliminate a bend.
I'm assuming you'll be changing out that old 3-handle tub/shower valve to meet current building codes of anti-scald tech?!
Tuttles Revenge
you could mount the 90 to the block and attach the PEX prior to mounting the block to the studs.. otherwise you have no access to the tabs.
