CSV questions
Banjo Bud
Active Member
South Carolina
I am hooked up. It was a nasty project. I'm more sore than I've been in years. So, the CSV valve needed a bit of adjustment to maintain 50 psi with a faucet running. My pressure switch is set to turn the pump on at 40 and off at 60. My PK1A tank is set to 38 psi. Everything seems to be working as it should, I think. My question has to do with pump run time. When I turn a faucet on, the pressure gage slowly drops from 60 to 40, as it should. The pump comes on and the pressure rises to 50, all is good. When I turn my faucet off, it takes 43 seconds for the pressure to go from 50 to 60 and turn off. Is that good number? Also, if I turn a faucet on, wait for the pressure to drop to 40, the pump comes on and I simultaneously turn the faucet off, it takes 58 seconds for the pump to reach 60 and turn off. It that a good number? Thanks guys.
Boycedrilling
Royal City, WA
Without knowing what size your pressure tank is, sounds like it’s dialed in pretty good. Very worst case is 58 second run time. Other wise is the amount of time you use water after the pump kicks back on, plus 43 seconds.
Banjo Bud
Active Member
South Carolina
Can I safely increase the pressure by 10 psi? Raise the tank to 48, raise the switch to 50-70 and increase the CSV to 60?
With a jet pump, you usually want the air precharge to be about 4 psi below the cut-in pressure. Sometimes more.
You did not say what pump you got, but you want the pump to be able to hit the cut-off and have some margin.
I have a Gould’s J5SH pump. Not sure what you mean by having some margin.
The J5SH is the high pressure version, so it should have plenty of pressure margin to go 50/70. The J5S or J7S would not.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
You really don't need the tank air pressure any different with a jet pump than a submersible. If a jet pump is primed it will come on and pump water just as quickly as a submersible. If it has lost prime, the extra second or two from the lower tank air pressure isn't going to be enough for it to prime itself.
I think that we could agree that if you get a stutter in water pressure as the pump kicks on, drop the precharge a bit.
Banjo Bud
Active Member
South Carolina
Ok. Can you explain the relationship between the tank precharge and the low setting (pump turn in) in the switch? Why do they say the tank needs to be 2 psi lower?
When the pressure switch turns on, there is a small delay before the pump is delivering water. The pressure tank has to supply the water during that brief interval.
Banjo Bud
Active Member
South Carolina
I see. Now that you say that, I can see the gage drop a few pounds when the switch clicks on. Happens very quickly.
It does no harm to have the pressure dip momentarily then. But dropping a psi or 2 in the precharge could reduce that.
Banjo Bud
Active Member
South Carolina
The instructions on my CSV say that for my tank (4.5 gal), and pressure switch (40-60), my CSV should be set to 50. Ok. I did that, but I’d like a bit more pressure. Is there any harm in setting it to 54 or so?
No, as long as the pump can deliver enough pressure.
So typically would raise three things by the 4 pounds: air precharge in the pressure tank, CSV, and the big nut on the pressure switch. 3.5 turns on the pressure switch is about 10 lb, so start with 1.4 turns CW.
Banjo Bud
Active Member
South Carolina
So what’s the rule for the CSV? Should the pressure setting be midway between cut on & Off setting of switch?
Wondering
Alabama
I think you would just adjust your CSV to 54-55 and leave the pressure switch as is and also your air charge will stay the same. You are wanting more pressure while using water, correct?
That would lengthen the time for the pump to cut on, and would shorten the run time after water use stops.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Yep like Reach says, turn up the pressure switch and adjust the air in the tank accordingly, so you will get a little more run time. You don't want the pump to shut off for 30 seconds to a minute after you close all the faucets. Turn the pressure switch up to 50/70, set the CSV at 60 while running 3 GPM, and make sure there is 45 PSI air in the tank. You can have as much pressure as you want, as long as you have a large enough pump to do it.
