Sdsvtdriver
Hello,
I had a new WH installed about 18 months ago (AO Smith). Plumber replaced all connections to the house with new. The cold in and hot out are SS flex lines. I noticed significant corrosion on the cold inlet where the SS line connects to the WH. We suspected it was related to a used up anode rod and replaced with an electrical anode (https://terrylove.com/forums/index.php?threads/anode-rod-and-water-softener.72343/#post-536010 for reference). It turns out the original anode was ok and the electrical anode company suggested the corrosion was caused by a leak. Chalked all that up to a learning experience.
A few months later, the corrosion is returning. (Pictures: https://imgur.com/a/aIceE). I see no water leaking on the top of the WH. The hot side has no corrosion at all, so assuming both nipples are the same metal, there should be no reaction happening. Any suggestions?
