JackBurton
I had to cut out an old SV 4" cast iron pipe since it was split almost entirely from spigot to bell. At the upstream bell end of the bad pipe, I'm gonna be left with an incoming elbow spigot w/ lip that was caulked. Is there a band coupling that can accommodate the wider OD of the caulk lip and adapt it to 4" PVC? If not, I suppose I could cut the lip portion off but I wanted to check first. What do you guys normally do here?
