Compact Mini Split Wall Unit?
DIYtry
ny
Looking to put a single zone 24K BTU mini-split indoor wall unit in a tight space.
What would be the most compact and/or can be installed closest to the ceiling/wall?
I have been trying to compare specs from Mitsubishi, Daikin, and Fujitsu, but would appreciate recommendations.
Ceiling Cassette Unit doesn't take up any floor space they all make them. Still need room for service. Also make ducted air hander for a remote location.
Thank you! Would prefer a wall unit if possible as the cassettes will cost a lot more for unit and installation...
All manufactures should spec the minimum clearance requirements for wall units vs BTU size in the installation manual. What do you mean by tight space? Low ceiling or not much room side to side?
Thanks.
Not much room from side to side. The ideal wall to install the unit has windows with ~12" from window top to ceiling and ~36" from window to wall.
