DanMerk
- Messages
- 10
- Reaction score
- 0
- Points
- 0
Welcome me. New to the forums. I am a homeowner and I have more than average experience with plumbing. I am not a pro, but I love to cut copper and use fire. heh.
I have a question. Can someone give me some advice on cutting a soil pipe I dug up in my basement yesterday? I found an area in my basement where there is a floor drain. It is a 4" pipe with trap and it drains and holds water perfectly. I thought it was going to be cast iron, but after busting up all the concrete near it and digging up the soil I found it is clay pipe. Probably 4".
What we are trying to do is install a toilet on the first floor directly above this drain pipe in the floor which used to be a sink drain at one point back in the 50's. Like I said, its completely operable, but I have never cut clay pipe before. I can rent a pipe chain cutter from a local hardware store, but I am afraid to damage any of the nearby joints from any pressure or torque. Has anyone done this before? When the pipe is cut, I plan on putting a no-hub to PVC/ABS drain pipe and 90deg up out of the floor. Then I will run the necessary pipe up to the closet flange. Below is an image of the pipe I have to cut.
Here is the beginning of the dig. It was an old shower.
This is the hole. I want to cut right after the hub from the trap and put a no-hub connector on to ABS drain.
