I've searched all over the forum and learned A LOT, but still have one issue.
I have a all block house, interior and exterior walls, all exposed block no drywall to help hide the pipes, built on a slab with copper supply lines under the slab.
We have a pretty decent leak and knew this was coming. So we're going to re-pipe the whole house with PEX through the attic using one of the Viega Manablocs. I'm a pretty experienced DIY'er and may do some of it myself. The hardest part will be crawling through the low attic.
My question for you guys is, after I fish the PEX down through cells in the block wall, with hopefully a minimal hole in the block that I can cover up with a escutcheon plate, how do I secure the stub out (which will be copper I'm planning). I've seen the drop eared elbows, and some other pex to copper stub outs that are made to be made to be nailed to studs. I've got a few rigged ideas in my head, but what's the correct way to do this so that there is a solid stub out to attach to?
I'm familiar with the "old work" electrical boxes and they have been a lifesaver in my house. Best I can tell there is nothing like that for plumbing.
