If I would have to resume the 4 days curing process -- do not forget these are the toughest conditions of testing , no air present , a 3/32 thick mortar layer , 100% coverage , etc. --- I would say .....
1) GraniRapid didn't do what is supposed to do . Instead of 6 hours it took 60 hours with a question mark on cure still in progress .
Definitely needs more testing to see the real cure times .
2) Kerabond& Keralastic did exactly what it does best . Reliable and slow to cure , but it does it in decent times . Great coverage , a very good premium exterior mortar . Never failed me in over 20 years .
3) 254P did also great . Great coverage , slow cure , I like the uniform curing pattern happening under the glass . Good signs of a premium mortar .
4) 255M it is a strange mortar . I do not like how the humidity is dispersed in the curing process . I really hope that at the end of 7 days , the humidity is gone . Not a mortar I would use .
5) Nanolight , this mortar is hard to read . I am still not sure if the humidity is present or not under the glass , but it looks like it has signs of cure 3/4 deep around the perimeter , under the glass .
6) Ultralite , this mortar is also hard to read . I am still not sure if the humidity is present or not under the glass , but it looks like it has signs of cure 3/4 deep around the perimeter , under the glass .
7) X5 , this mortar has a nice texture , nice coverage , but the curing process is quite strange . It does a lot in the first 24 - 60 hours , but then it kinda slows down quite much . I was sure it would be done by now since the presence of the air is not required , but maybe it has other factors happening which slowed the progress .
8) X 77 , this mortar also has a nice texture and great coverage , but as the X5 , the curing process is similar . Since it is few levels more modified than the X5 , you would expect more interference or longer cure times .
I observed a slower rate of curing going on in the first 24-60 hours , but then it caught up with X5 and I can say they are quite similar in humidity levels at this point .
Alright , that's it for now .
