http://www.homedepot.com/catalog/pdfImages/1e/1e0bf4be-eb4e-445a-af11-9c22c8a69333.pdf
If I'm reading the spec sheet right, the rough in drain should be 2 inches from the sidewall. That is pretty much where the old plumbing is right now. For some reason, when I measure the this tub and other tubs at home depot, it looks more like that the drain is 8 or 9 inches from the lip of the tub. It may just be me trying to eyeball the tape measure. I just place the end of the tape measure in the middle of the drain hole, I then look down the back side of the tub.
Is it normal for the rough in drain to only be a couple of inches from the wall stud? What's the proper way to measure this, or should I just be going by the spec sheet?
