My limited experience with the rings and a hand expansion tool is maybe not. When I have had my pipe wet during expansion, the ring has slipped from the end of the pipe and onto the pipe. Maybe there is a technique to make that not happen. My experience is very limited. Maybe something as simple as tape to keep the ring from sliding onto the pipe would work. Even my finger might have resisted had I thought about that.
My workaround without cutting back the pex, was to expand a new ring separately before trying again. The connection then leaked there lightly. I put a hose clamp over the new ring to stop the leak. Eventually I removed the hose clamp and there was no leak; things had tightened with time. I waited a month or two. A much shorter wait would have probably been fine.
What I think would work with an expansion system is F2080 fittings, but that requires an added tool. That should work wet really well, it seems to me.
Other pex fittings, plus rings or stainless steel clamps, would work with the more common type of fittings (but smaller ID). You can still use the PEX-A tubing.
Sharkbite would work.
