Scott Roberts
Hi, I just bought a home that I think has an unique situation. An unregulated main comes into my basement and splits into two sides. One side services the internal home plumbing ie bathrooms, kitchen etc. and the the other side services the irrigation bids outside the house. The side that services the internal home has a regulator on it set to 50psi. The irrigation side is unregulated. Directly coming off the unregulated main I have installed a Phyn main water controller. Problem, the city just bumped up the service pressure to 142 which doesn't effect the internal home but the Phyn controller will now not work at this high pressure.
Question: Can I install a second regulator before the Phyn device? This will put two regulators in series for the internal home service.
Thank you
Thank you
