Pronouncedeyen
I'm running a 2" PVC drain pipe from one room to the next to connect to the main stack. The most convenient height (plumbing-wise) for it to pass between the two rooms is through part of the top plate of a load bearing wall. It's an old house so the top plate is made of 2 actual 2x4s. The top of the drain pipe lines up exactly where the 2 2x4s meet.
Can I cut through the bottom 2x4 to run the pipe? If so, do I need to reinforce that 2x4 from underneath somehow?
