Can anyone review my DWV Sketchup Plan?
Bradley Grillo
Maine
Hi first time caller long time listener - I'm renovating a house and moving everything around. Before I start roughing in I wanted to see if I made any mistakes according to the 2015 IRC. I have attached the drawings (all pipe is PVC 2" and 3")
The specific questions I have are:
- I need (2) 1/8 bends to change direction in the 2" vent above the kitchen sink because the wall is sloped. Does it need to be at least 6" above the sink?
- I have 3 cleanouts as shown. There is less than 40' between them. My last cleanout is 20' from the foundation wall. After the pipe goes through the foundation wall, there is 12' until it dumps into the septic tank. Do I need a cleanout outside or is the septic tank close enough?
Your tub trap should be vented before joining the toilet waste or laundry waste. Same with showers.
I did not see anything that looked like a kitchen. However 45 from vertical is considered vertical, so the answer to what I think you are asking is no.
I don't know.
Thank you Reach4 - Are you saying I should have a vent upstream of each fixture instead of downstream? Is this necessary for toilets too? I currently have the vents for everything located downstream if they enter a horizontal drain
I don't know IRC, but I was thinking of bringing the vent to the tub (or shower) trap arm before it joins the laundry and toilet waste. I hope you get some more views. I am not a plumber.
