Bypass valve
Petersam
North Bend, Oregon
i have just switched over from spring water to a 140' deep well. The spring was very acidic, the well has good neutral water. A few years ago I installed a up flow media system, and it has been working pretty good.
Now I don't need it anymore so my water to the house is grayish with sediment in it, now do I close the bypass valve or open it to keep the calcite from entering my house???
Bannerman
Ontario, Canada
By closing it, the water will bypass that device.
If it is a purchased bypasas, depending on the type, it may have either one or two handles to close. They will usually indicate the bypass position.
If it is a three valve bypass constructed onsite, it will not be labeled but two will need to be closed and the third is to be opened.
Petersam
North Bend, Oregon
thanks and ok I did close it but the water is still murky coming to the house, I suppose after awhile it will clear up?
Akpsdvan
Alaska
Sounds more like you need to run the well at full for about 3 days straight, no off time.... flush the well.
ditttohead
Water systems designer, R&D
Ontario California
Many wells will have sediment, clay, turbidity issues etc. Can you post the water report? This will usually have a SDI/color report included.
_John_
Texas
a greyish sediment sounds like the well may not be fully developed. If it is that and just not a characteristic of the water, then running water as mentioned is good.
