Burying water line into bedrock
Slugboy6000
Ontario
Hello,
I have a drilled well with a 6" x 20' steel casing. Due to shallow bedrock, the pitless adapter is installed at only 12" below grade.
That's not deep enough to prevent freezing here in Ontario.
How insane would it be to chisel down through some bedrock and sink my water line below frost depth? It's a short ~8' run from the well to my pressure tank. I'd have to install a new pitless adapter below the original and seal the old. Would removing bedrock compromise the grout seal on the casing?
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
The seal should be deeper than the frost line. But if there is no seal when you get down there, you will need to go a few feet deeper and seal below the pitless as best as you can. Best of luck with the chiseling.
VAWellDriller
Active Member
Richmond, VA
Might be a little easier to build a little pump house to cover the 8ft run....I don't have any experience trying to run waterlines in hard rock but it can't be very easy. Other thought since it's only 12" would be to run it in a large conduit, with some heat tape or heavily insulate like with some commercial grade spray foam.
Slugboy6000
Ontario
Thanks for the tips.
Another option that I found was to use a drain back system. I believe it requires a bladderless pressure tank and a snifter valve... but I've only read about it.
I think leaving for the winter would be easier.
Another option would be to have enough XPS foam insulation above the shallow parts. And that would need to extend out so that heat has a long path to go around the insulation.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
A drain back system with a regular air over water tank will work. Probably why it was set up that way. However, for a drain back system to work you will need to maintain the bleeder orifice, control check valve, Schrader valve, and air volume control or AVC. These four parts are problematic, which is why bladder tanks are more popular as they don't have the maintenance issues. But if you make sure these four parts continue to work the water will drain back and eliminate the chance of freezing.
