mnRemodeler
The whirlpool tub I'm installing has an inline heater built-in. I ran a separate 20amp GFI for it.
I did some checking and learned that it keeps the water temperature at 104 degrees which is the same as a hot tub. Apparently it has no thermostat that can be manually set. Its preset to 104. To say that I'm a little ticked off is to put it mildly.
So...what I'm wondering is if I should run a wall mount switch for that outlet so that I have the option of disabling that heater for people who don't care for the hotter temps? I'm assuming there is no pump in the heater and that the heater does not need to be turned on for the rest of the tub to work properly?
