Bathtub drain pipe confusion
CC_CT
CT
Hey folks, first of all thank you for your expert opinions that you share on this site. I've learned a ton from reading on this forum.
I'm preparing to replace my 30-year old tub with an acrylic one, and I opened up an access wall to see what was going on. As you can see in the pictures, the drain pipes are copper and connect to the ABS plumbing via the slip nut fitting. Then there is the p-trap which connects to the vertical ABS pipe you can see at the wall. I plan on replacing the copper pipe with ABS piping.
I was a little surprised to see an extra "joggle" in the copper pipe where the tub drain and overflow drain pipes meet, before it hits the ABS p-trap. Most of the tub drains I'm seeing online go straight down and connect to the p-trap directly.
My question - when I replace the copper with ABS, is it a bad idea to mimic the shape of the copper pipes and attach to the existing slip nut? Or should I cut away the old ABS trap, attach/extend a new ABS line, and put the p-trap directly under the tub (and thereby getting rid of that joggle)?
Any help you can offer would be greatly appreciated. Thanks!
Get rid of all the brass and use all new ABS fittings and tub drain. There is no reason to reuse the brass.
And install the p-trap where it makes sense, normally below the vertical on the waste and overflow.
CC_CT
CT
OK perfect, thank you. I didn't know if the extra joggle before it got to the p-trap would cause an issue. I'll plan to relocate the p-trap to under the tub.
Thanks for your help!
Dj2
California
Replacing a tub is relatively a big job, therefor you should only use new connectors and pipes through out.
Do it correctly, do it once.
