Bathroom DWV question
spidey417
New Jersey
Hi, first time poster!
I've learned alot about plumbing here about using proper fittings such as long sweep elbows and combo wye's.
I've attached a diagram of the two bathrooms I'm remodeling at my home and wanted to know if the Master WC and Hallway Tubs are considered wet vented here. (see layout and DWV diagram).
Any help and advice is greatly appreciated!
  • Plumbing Layout DWV Diagram.pdf
spidey417
New Jersey
HJ - thank you so much! will change drain line coming from kitchen and lavatory drains to 2"! Also will vent hallway tub!
spidey417
New Jersey
HJ - Can ask you one more question? Can I use a 3" x 2" double combo tee wye on top of the soil stack? Or should i use a 3" x 2" double sanitary tee or double fixture tee?
