I have, on order, a Sterling bathtub/shower kit. It shows specs for a 2" drain.
Under where the shower will go I have a 3" ABS pipe. Wife wants one of those cable driven things to be able to pull the stopper.
It seems that there is a limited number of options with all the specs/finish we're looking for (brushed nickel) in ABS.
Would you use a transition at the drain to go from the PCV (on the drain kit...there are lots more options for ABS) to ABS. Also, I'll need to transition from a 2" pipe to the 3" waste/drain underneath.
Any recommendations?
