Basement Pre-fab shower
Outdoorbum
Oregon
What is the recommended method for installing a pre-fab shower in a basement where one wall is concrete block? I don't know if I should put a kerdi building panel over the block and then anchor the shower walls to that or what would be best. The wall is generally dry, but I can only assume there's moisture in there at some point. I have contemplated putting those kerdi building panels on the block and the other studded walls, thereby creating a waterproof enclosure then placing the pre-fab in the alcove. Probably overkill since it won't be tile, but I've lived with my share of leaky shower set ups.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
I'm a plumber, not a builder, but possibly you would want whatever you use to have a ventilated gap before whatever you use next.
True barrier and proper sub drainage on outside the basement wall (ie drainage mat on the wall and normal piped subterranean setup). I'm thinking for any residual interior moisture you don't want to completely trap it with a interior panel.
But maybe if you use a completely waterproof panel, then maybe it would be ok.
