Outdoorbum
What is the recommended method for installing a pre-fab shower in a basement where one wall is concrete block? I don't know if I should put a kerdi building panel over the block and then anchor the shower walls to that or what would be best. The wall is generally dry, but I can only assume there's moisture in there at some point. I have contemplated putting those kerdi building panels on the block and the other studded walls, thereby creating a waterproof enclosure then placing the pre-fab in the alcove. Probably overkill since it won't be tile, but I've lived with my share of leaky shower set ups.
