Backfill material for slab trenches
CaliforniaPlumber
San Diego, CA
Hi,
What would be the best backfill material once I am done with the plumbing?
The trenches are about 9” wide, and 5”-14” deep below slab, probably averaging 10” for a total of about 1-1.5 yard of backfill.
I did a lot of research, and found the following. I am leaning towards the easiest one, sand.
- sand. Pros: cheap, less labour: easy to spread evenly, the existing dirt/foundation walls will ensure no compaction needed.
- flowable fill. Probably best but more costly. (Would that be much different than wet sand mix?)
- pea gravel. Would require fabric between dirt. Would need some compaction. 3/4 sharp gravel to be avoided due to pipe damage risk.
- dirt. Would require a lot of compaction, might be risky for pipes.
Which one would you do? Any concerns on going with sand?
Thank you
we like road base rock when filling under piping where too much soil has been removed.
Pack it in with maul/sledge.
