AquaSource Garner, Gap between shower valve cover and wall
Andy Westmoreland
Grand Rapids, Michigan
I recently had an AquaSource Garner Brushed Nickel Pvd 1-Handle Tub and Shower Valve (Lowe's Item #: 40252 | Model #: 873-3804) installed.
Should the valve cover be this far from the wall (see image, below)?
(Animated version showing amount of play here: http://i.imgur.com/W0Vyqay.gifv )
There's a spongy, waterproof seal behind it (like a gasket) but there are no screws or anything to pull/hold the cover closer to the shower cubicle wall.
Thanks for any feedback you can give.
Plumber69
Prince Rupert, British Columbia
Someone lost the screws. There about 3 inches long. Usually the same ones are use to hold that black gaurds that was on during rough in
Andy Westmoreland
Thanks for the quick response!
I've seen the screws you're talking about along with the black guard (they're in the box the fixture came in) but there aren't any holes in the valve cover where you'd typically expect them to go.
Your suggestion sounded plausible though so I brought up the installation instructions online, but they don't mention anything about it.
http://pdf.lowes.com/installationguides/6925699900728_install.pdf
I'm wondering if the faucet itself is what presses the cover against the wall, and - because of the pipe length - it's too far away from the wall to do that?
9. Position the escutcheon (E) over the valve body (D). Attach the handle assembly (F) by threading the base of the handle assembly (F) onto the valve stem of the valve body (D) and twisting clockwise until secure. Do not overtighten the handle assembly (F) as this could damage the escutcheon (E).
Andy Westmoreland
Are you suggesting the handle could just be twisted tighter? I haven't tried it (I wasn't the one who installed it), but I will; I just assumed it was on as tight as it would go.
Sluggo
Washington
I hate to say this, but one other possibility is that the valve was installed a little too close to the finished surface and there may be no room left for further adjustment. You can figure if this is so by removing the handle and escutcheon, measuring the depth of the valve, and comparing it to the parameters that are shown on the installation sheet for the valve...Recommended valve depth to finished wall: 2" min., 2-1/2" max.
Plumber69
If this was the case he could always remove the foam gasket.. Load it with silicone and drywall tape it till it settles. I think it would be flush then
Sluggo
Washington
Yes, I thought of that, too. A little hard to remove in the future if siliconed, but a lot better than the leak magnet it is now!
Andy Westmoreland
You're right, Sluggo! Looking more closely at this, I can see there's about 1.5" of play in the thread of the handle, but even at its tightest, it doesn't come close to touching the cover. Am I correct in thinking the threaded portion of this valve should end about level with the wall surface?
The second image shows the shower at rough-in stage. I'm thinking at this point, the only option is to cut an access hole in the rear wall, remove one of those cross-braced 2x4s, and reattach the valve. Do you agree?
Plumber69
View attachment 31603 View attachment 31604
Plumber69
If that's a tub shower you can't run pex to the spout or water will come out spout and shower head at same time
I concur. All instructions warn about using PEX to a tub spout. The size is too small, therefore forcing water out of the shower head while running the tub.
You can either put a space behind the wall plate on the valve, or move the board back.
Andy Westmoreland
Ah, I misunderstood what Plumber69 was saying. I haven't noticed the problem, but to be honest I haven't played with it a ton. Maybe my the low pressure at this house will save me there.
Still, too late now; the wall has been cut open and re-sealed. Here's what the install looks like now.
Thanks for helping me think/talk this through, guys. Much appreciated!
