Air in lines, worse after well pump replacement
Kaitie
Pennsylvania
I see this has been asked about a thousand times. Had air in the line, it was worse in the mornings or if it hadn't been used in a while. We could hear the air pull from outside when the pressure tank kicked on (bladder tank). Plumber came out and replaced well pump, well pipe, pitless adapter and all the wiring down there. When they took everything out, said it looked like a diy job, pump was from 2002, house built in 1987.
Water was fine for about a week but the air has come back with a vengeance. Now it's every time we turn the water on day or night, sputtering a lot, pipes are knocking. It was just upstairs but now is happening in the sink next to the pressure tank too. Pressure has stayed fine the whole time, and is actually better than it was before the pump was replaced (could this be part of the issue?) Still hearing it pull from outside when the tank kicks on.
Plumber is coming back, but I also wanted to get some opinions on what I should have him check out more.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
And a thousand times we started the diagnosis with needing to remove the check valve at the tank. If then, the pump cycles on when no water is being used, you have a hole in the drop pipe or the check valve on the pump is not working.
I presume the pump is down the well, because only a few above ground pumps are piped through a pitless.
So it may be that a few feet below the pitless is an intentional hole or a drain-back valve that was put in when a pressure tank without captive air (bladder or diaphragm) was not used.
Leak could be near the pump where the PVC melted when the old pump failed.
Did you follow about the above-ground check valve or check valve anywhere but at the pump?
Tell us more about "We could hear the air pull from outside when the pressure tank kicked on ". Outside by the well casing?
When the pump runs and you stop using water, how long until the pump shuts off?
Kaitie
Pennsylvania
We're not hearing any issues with the indoor check valve. The air pulling can be heard inside, near where the pipe comes from outside (blue arrow in photo, straight part, not elbow).
Pump shuts off after 25 seconds once water stops running.
So what is letting the water out?
As far as the air coming in, you could slather that elbow near your blue arrow with shaving foam. If air is sucking in there, then you found your point of air entering.
It may or may not be that that leak so small that no noticeable water could come out. Air goes through smaller cracks
Do you understand the suggestions regarding getting rid of the down-hole water leak? Do you understand the advantage of not having a topside check valve?
That tank (14 or 20 gallons?) is less than half as big as you ideally would have.
Do you know the model of pump down there? If they pull it, take photos of the two labels on the pump assembly. One is for the motor and one is for the "wet end" (tho both are wet).
You might benefit from a CSV.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
The indoor check valve can cause the check valve in the pump not to seal which then creates a partial vacuum which will suck in air and/or contaminated ground water which is why that check valve is illegal in most states. Remove it.
Poly pipe connections to barb nipples should have two jubilee clamps, not just one.
Kaitie
Pennsylvania
Apologies for not knowing anything about all of this, we are really relying on our plumber. Well pump that was installed is a 1/2 hp 220v 10 gpm pentair. Well is 125' deep. I'll put shaving foam on the elbow and see if any air is leaking there.
Reach4 I think we're confused about this, they completely replaced the well pipe when they installed the new pump. There was no mention of an additional valve or hole when being installed. Or are you talking about between the pitless and the basement interior?
LLigetfa thank you, the previous owner did a lot of DIY fixes/upgrades. We're constantly finding things they did incorrectly.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
If that leak on the main line had been underground, it would be sucking dog crap and pesticides into your water system. That is one reason why in states with engineers who have any common sense, check valves above ground are illegal. Remove that blue check valve just under the pressure gauge. If the added pressure from the pressure tank doesn't cause the check at the bottom of the well to start sealing off again, the pump will need to be pulled and replace that check valve.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
You should hope it is sucking air from that spot instead of somewhere else underground. If you do not remove that check valve, next time it could be underground and you would be drinking ditch water without knowing it.
Kaitie
Pennsylvania
Edit - nevermind, I realized what's required is called a dual check valve, not two check valves. We are located in Pennsylvania, I was reading the Safe Water Act Law.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
A double check or an RPZ can be used after the pressure tank on the line going to the irrigation. But there should never be any check valve before the pressure tank except for the one right on the pump.
The new pipe removes my suspicion about a the hole or drain back valve. So lacking that, how is the water leaking out, which creates the vacuum?
With the topside check valve gone, or deactivated by removing its innards, it may fix that problem. Or if there is a small leak, the pump might run every hour to make up for the leak. Or it could run every 2 minutes indicating a significant problem.
I don't know if a pitless o-ring problem could cause your symptom. People often recommend replacing the o-ring each time the pump is pulled. Your MN pitless might be lower than the basement check valve if the ground falls on the way to the well.
LLigetfa
NW Ontario, Canada
Some folks cannot grasp that a fitting can leak under suction but not under pressure. Double up all those jubilee clamps and stagger them on opposite sides. Your plumber needs a lesson or two or you need a new plumber.
Kaitie
Pennsylvania
We'll do that. I left shaving foam on it for hours and there was no indication air was being sucked in at that elbow.
Wanted to add, we have a whole house pressure monitoring/leak detection system and this entire time we have never had a dip in pressure (except for when water was being used) or any indication of a leak. Not sure if that's helpful or not.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
The pressure monitor will be very helpful after you remove the check valve at the tank.
There also was no repeat of the indication that the air was leaking in elsewhere. It could be that a little foam got sucked in and closed the path for now. Was the sound you heard before intermittent, or did it occur each time the pump stopped running?
