Air handler to duct connector
Bratan
New York
I recently noticed that one of the ducts came loose from air handler in the attic. It seems that duct tape was all that was holding it there. There's about an inch of collar sticking out (6.5" diameter), and I'm unable to reconnect duct back to it, cause it's soft and keeps slipping off. Is there some kind of adapter I can buy at hardware store to make connection? Duct itself seems to be about 7" diameter, does that sound right?
Bratan
New York
I figured it out. I didn't know that there were 2 layers of duct (inner and outer). Once i exposed inner duct I was able to slip it on easily. Now I need to get a nice long zip tie. Is there something better than duct tape to secure the seam?
They make a metalized foil tape to seal ductwork. A big worm clamp may work out better than a zip tie to hold it in place since it is usually wider and you can tighten it easier. The adhesive on that stuff is permanent, or about as permanent as it gets.
Dana
In the trades
Either a temperature rated heavy duty foil tape like Nashua 324A (available at box stores) or a temperature rated aluminum FSK tape with a paper backing should work. Cheaper no-name stuff with no temp ratings on the adhesives aren't likely to cut it.
