Air gurgling sounds
webmusic
Hi,
I'm getting air gurgling noises every time my water pump starts.
It's a submersible pump with an Amtrol Champion tank.
The noises start when the pump starts, then subside until the cycle is almost over, then I get a few more noises. At the beginning they are loud.
Do you think I need a new check valve at the tank?
I have a filtration system after the tank because of rusty water and sulfur odors. Maybe a filter before the tank?
Open to suggestions.
Thanks....
Raucina
If its a plain tank, its most likely an air makeup valve in the well doing what its intended to do, add air to the system.
