My question is related to a CPVC fire sprinkler system, but isn't directly related to the system operation.
I intend to install a bleed valve in the attic, at the highest point in the system. It would be very convenient for me to pipe this laterally into a lav or washer/shower vent 15 feet away, just prior to these vents penetrating the roof.
Although the fire system was designed and installed by a licensed installer, and inspected / signed off by the fire marshal, it doesn't include a way to bleed entrapped air from the high point in the system, as recommended by BlazeMaster and FlameGuard.
And of course it isn't just air -- it's air followed by spurts of water until there's a smooth and steady stream flowing.
My thought is to install a ball valve at the tippy-top of the CPVC riser, connected to gently sloping ½ copper (to encourage drain-off), into a wye that I would splice into the ductile iron vent. It would only get used when I have to refill the fire sprinker system after maintenance.
My hesitation isn't the usual "unknowingly sucking a trap dry" type of wet vent concern, but of any unforeseen problems with a non-air gapped connection of what's essentially an extension of the domestic water system directly to the DWV system. We're taking a 3-story installation in an attic, serving one or two fixtures, so there's about zero chance of a waste water backup up here. And despite this, I'm considering a second ball valve at the wye just to positively isolate the two systems.
The alternative is to run my line a bit farther, penetrate an exterior wall, and vent to the outside, but there's some ladder work, stucco drilling, and weatherizing I'd rather avoid.
