We recently purchased a newer home with a well and would like to put in a water conditioning/filtration system. I'm more concerned with improving the quality of the water if possible than the cost of an effective system. Currently we don't consider the water drinkable due to the taste.
Water system details:
- water flows from well into 2500 gallon holding tank, then to a pressure tank and into home.
- 2.5 bathrooms
- 2-3 people living in home
Attached is the water analysis from National Testing Laboratories I just received.
Here are some of the concerning water analysis data points which stood out to me.
Total Coliform present - but no E.Coli
Sodium - 519 mg/L
Sulfate - 140 mg/L
Hardness? Not sure why this wasn't detectable. I measured at 25ppm with Hatch test
Alkalinity - 1100 mg/L
TDS - 1400 mg/L
PH - 8.4.
As this is water from a well I'd like to also add a properly sized UV filter assuming the water can be cleaned up as needed to allow this to function correctly. Any recommended UV filter brands?
Given these results, I'd like to hear feedback on what system components would best improve the water quality. There is room to install most any necessary water filtration/conditioning equipment. If I've missed any critical information necessary to provide a recommendation, please let me know.
Thank you in advance for any assistance you can provide.
- 2.5 bathrooms
Sodium - 519 mg/L
Sulfate - 140 mg/L
TDS - 1400 mg/L
PH - 8.4.
