VTMBZ
My sugarhouse is unheated but I need to have running water in it during syrup making season in the early spring. I have a shallow (10’) well with a heavy duty submersible pump, capacitor start 220v. But since the building is unheated I dont want to use a pressure tank, as that would freeze in this northern climate. I just throw the disconnect on when I need water.
THe problem is that the pressure is way too much for practical use. I installed an outside faucet to relieve some of the pressure, but its still way too much water at once. I want to put a ball valve in the supply line from the well and throttle it back to about 20psi. How much can I throttle that pump back before I ruin it?
In use I would probably never use it more than ten minutes at a time in throttle position: mostly just to flood the floor and for hand washing. Will I overheat the pump?
