Olmedo
I'm asking about the end of the drain line at the bottom center of the design. Am I able to use a 3" Sanitary Combo and then reduce the drain to 1 1/2" for the lav drain? That is the only fixture that will drain there. Or do I have to run the 3" line above the cleanout before reducing? Code is UPC with no applicable amendments. Thank you
