Theeplaymaker
So I posted about this before and thiibk I have everything figured out. Before I get started I wanted to make sure this will work and ask for any advice on improving it. This will all be in a water closet in my basement that's about 50-65 sqft. I will only be using 1 well at a time, but since they are both low yield I want the option for a backup and easy switch. I have one cycle sensor for whichever well pump is running.
My main questions/concerns:
1. Is it okay to put the sediment filter right off the well pump and dump into the storage tank like I have it?
2. Is it okay to run the wells wide open into a tank like this? Can I throttle them back with the valve?
3. Do I need the 1" the whole way or is it overkill?
4. Will I have any issues with build up in the storage tank? Like I said it's semi conditioned and dark in the well room off my basement.
Thanks for any help and I hope I added enough info to help me sort this out.
http://i.imgur.com/hEpbYQL.jpg
